Home › Forums › Products › Stompboxes › PitchFactor Preset Programming: “Other” Effects › Reply To: PitchFactor Preset Programming: “Other” Effects
Time to drop another batch of presets. Along with the rest of the entries above, these are basic configurations meant to be tweaked and customized.
AttackTremolo
Mix = WET:100
Pitch Mix = A10+B10
Pitch A = ArpA: OFF
Pitch B = ArpB: OFF
Delay A = GrvA: A06
Delay B = GrvB: B06
(encoder) = PEGGIATR / TMP ON
Show More...Depth / Key = ATK: 5
Speed / Scale = LN: 1/8
Xnob = FXA: OFF
Ynob = FXB: OFF
(EXP PED Heel) = ATK: 5
(EXP PED Toe) = ATK: 0
This patch emulates a sawtooth-like LFO controlling amplitude, for a different kind of tremolo effect. It can also be used as a steady slicer at different rates, or a fake delay effect (using the guitar's natural decay). It has a sharper ramp characteristic on the groove "slices" than the usual sine- or square-wave LFO on many tremolo units.
Expression Pedal:
Pushing the expression pedal towards the toe position fades out the sharp attacks, and becomes a subtle pulsing that's barely audble. Use it actively to vary the solid pattern emphasis.
