Home › Forums › Products › Stompboxes › PitchFactor Preset Programming: “Other” Effects › Reply To: PitchFactor Preset Programming: “Other” Effects
VibratoWhammy
Mix = WET:50
Pitch Mix = A10+B0
Pitch A = 50c
Pitch B = -50c
Delay A = 0 ms.
Delay B = 0 ms.
(encoder) = MICRO / TMP OFF
Depth / Key = DPTH: 100
Speed / Scale = SPD: 80
Xnob = FBK: 0
Ynob = FLT: 0
(EXP PED Heel) = WET: 0
(EXP PED Toe) = WET: 100
Wide vibrato or whammy bar effects are available in this preset. Speed / Scale is set for a moderately-fast, "natural" rate. Increase or decrease that by 10% or so for faster & slower "natural" effects. Vary the speed much more to dive into "electronic" rates. Pitch Mix is shifted to the left for a "bend up" quarter-tone vibrato. Change that to A0+B10 for "bend down", or to A10+B10 for both directions simultaneously.
Expression Pedal:
The pedal is set up to fade in vibrato effects from no vibrato, through an equal blend, and landing on total pitchbending. A rapid move through the pedal range will emulate near-instant vibrato.
