Home Forums Products Stompboxes PitchFactor Preset Programming: “Other” Effects Reply To: PitchFactor Preset Programming: “Other” Effects
#135199
    RotoGrinder
    Mix = WET:85
    Pitch Mix = A10+B10
    Pitch A = A:01
    Pitch B = OFF
    Delay A = GrvA: A03
    Delay B = GrvB: B20
    (encoder) = PEGGIATR / TMP OFF
    Depth / Key = ATK: 5
    Speed / Scale = LN: 22 ms.
    Xnob = FXA: OFF
    Ynob = FXB: OFF
    (EXP PED Heel) = LN: 50 ms.
    (EXP PED Toe) = LN: 10 ms.
    Minimal pitch shift is used here to accent the cyclical machine sound.  This is an unusual effect that may be useful in more limited applications.  It has an electronic type of overlay with an emphasis on grinding, non-tempo sync'ed rates.  Complexity is added by allowing a small amount of the dry signal to leak through.
    Expression Pedal:
    Control over simple rate changes from relatively slow to maximum speed.  Change the Heel setting to 250 ms. to bring the machine to a grinding halt.
