Home Forums Products Stompboxes PitchFactor Preset Programming: “Other” Effects Reply To: PitchFactor Preset Programming: “Other” Effects
#135200
    RandomChops
    Mix = WET:100
    Pitch Mix = A10+B10
    Pitch A = OFF
    Pitch B = OFF
    Delay A = GrvA: A06
    Delay B = GrvB: B06
    (encoder) = PEGGIATR / TMP ON
    Depth / Key = ATK: 0
    Speed / Scale = LN: 1/16
    Xnob = FXA: RnGL
    Ynob = FXB: RnGL
    (EXP PED Heel) = ATK: 5  LN: 1/4
    (EXP PED Toe) = ATK: 0  LN: 1/16
    All out and straight-up glitching.  The default settings demonstrate the variety of glitching effects available, and the glitching patterns for each processor are tossed out randomly.  The effect can be subtle and yet surprising; depending on what you're playing, and what the PitchFactor "decides" at that particular moment.  This can be used to add synthetic pick attacks to guitar.
    Expression Pedal:
    The expression pedal at the Heel increases the groove pattern attacks, while decreasing the time division rate.  This position can audibly knock out some of the glitches, while emphasing the more rhythmic groove patterns.  The Toe postion shifts back to the default preset settings.
