Home Forums Products Stompboxes PitchFactor Preset Programming: “Other” Effects Reply To: PitchFactor Preset Programming: “Other” Effects
#135201
    MurfFilters
    Mix = WET:100
    Pitch Mix = A10+B10
    Pitch A = OFF
    Pitch B = OFF
    Delay A = GrvA: A06
    Delay B = GrvB: B06
    (encoder) = PEGGIATR / TMP ON
    Depth / Key = ATK: 1
    Speed / Scale = LN: 1/16
    Xnob = FXA: FLT1
    Ynob = FXB: FLT1
    (EXP PED Heel) = FXA: FLT1  FXB: FLT1
    (EXP PED Toe) =  FXA: FLT5  FXB: FLT5
    OK, so Moog isn't worried about going out of business with this preset.  But the PitchFactor can provide a nice selection of sequenced filter effects.  Identical filter patterns in each processor (plus the 100% wet signal) add a strong rhythmic presence to chained pedalboard effects.  Pre- or post-distortion always gives filters more harmonic content to chew on.  Pulling back the Mix knob to 50% pushes the filter effects towards the background.
    Expression Pedal:
    Five filter patterns are available through the range of the expression pedal.  The limited number of positions makes it relatively easy to lock into any of the filter sequences with most expression pedals.
