Home Forums Products Stompboxes PitchFactor Preset Programming: “Other” Effects Reply To: PitchFactor Preset Programming: “Other” Effects
#135202
    BowedReversal
    Mix = WET:75
    Pitch Mix = A10+B10
    Pitch A = OFF
    Pitch B = OFF
    Delay A = GrvA: A02
    Delay B = GrvB: B02
    (encoder) = PEGGIATR / TMP ON
    Depth / Key = ATK: -5
    Speed / Scale = LN: 1/16
    Xnob = FXA: OFF
    Ynob = FXB: OFF
    (EXP PED Heel) = ATK: -5  LN: 1/8
    (EXP PED Toe) =  ATK: 2  LN: 1/64
    A slow attack preset that is vaguely reminiscent of up/down bow technique on strings, or a rhythmic reverse delay.  Quite a different effect from using the PitchFactor's Crystals mode (more like soft tremolo effects or reversed ducking delays).
    Expression Pedal:
    The expression pedal flips the attack from a slow fade-in to mildly staccato.  The rate of the repetitions increases at the same time, while maintaining a time division relationship to the current tempo.  Use the expression pedal almost like you would a Leslie, with the rates moving slowly around the tempo.
