Home Forums Products Stompboxes Ultimate P/T/MFactor control with Musicomlab MKIII Reply To: Ultimate P/T/MFactor control with Musicomlab MKIII
#135220
    Hi Mr. Gas
    I'm not an expert on Midisport – but any MIDI pedal should be able to control 3 factor pedals if set up properly.
    Or, it might be easier to use a regular pedal and a 3-way lead. Either way, you will probably need some local technical help.
