Home › Forums › Products › Stompboxes › PitchFactor Preset Programming: “Other” Effects › Reply To: PitchFactor Preset Programming: “Other” Effects
#135310
    CirclePickFlip
    Mix = WET:100
    Pitch Mix = A10+B10
    Pitch A = ArpA: OFF
    Pitch B = ArpB: OFF
    Delay A = GrvA: A07
    Delay B = GrvB: B02
    (encoder) = PEGGIATR / TMP ON
    Depth / Key = ATK:  -5
    Speed / Scale = LN: 1/32
    Xnob = FXA: OFF
    Ynob = FXB: OFF
    (EXP PED Heel) = A10 + B0
    (EXP PED Toe) = A0 + B10
    Another two-pattern slicer preset.  One sparse groove pattern combines with a more active pattern to produce a third 'pattern' with some characteristics of each.  *Note:  No guarantees in a mono routing using the expression pedal.  For some reason, groove pattern B suffers from cancellation.
    *Expression Pedal:
    The expression pedal shifts the Pitch Mix between the A & B sides.  Groove A can be used as a fake delay or slow tremolo.  Groove B doubles the rate and varies the amplitude of alternating steps.
