Home Forums Products Stompboxes PitchFactor Preset Programming: “Other” Effects Reply To: PitchFactor Preset Programming: “Other” Effects
#135311
    FakeFlanger
    Mix = WET:50
    Pitch Mix = A10+B10
    Pitch A = A:  1.000
    Pitch B = B:  1.000
    Delay A =  0 ms.
    Delay B =  0 ms.
    (encoder) = 910/949 / TMP: OFF
    Depth / Key = MODERN
    Speed / Scale = MICRO
    Xnob = FB-A:  75
    Ynob = FB-B:  75
    (EXP PED Heel) =  FB-A: 50  FB-B:  50
    (EXP PED Toe) = FB-A:  100  FB-B:  100
    At default settings, this is a fairly subtle 'slow flanger' effect.  The delay times are set to 0 milliseconds with significant amounts of feedback.  Unintended pitch shifting from the MICRO mini-mode combines with processing delay regeneration to produce 'sweeps' in opposite directions.  No direct control over the 'sweep rate'.
    Expression Pedal:
    At the Heel, the slow 'flanging' is barely noticeable.  At full Toe, the feedback gets pushed into runaway oscillation.  Full 'barberpole' effects travelling in two different directions are available near the Toe position.  Midway is about where the default preset settings start out.
