Home › Forums › Products › Stompboxes › PitchFactor Preset Programming: “Other” Effects › Reply To: PitchFactor Preset Programming: “Other” Effects
#135312
    EnvelopeChorus
    Mix = WET:50
    Pitch Mix = A10+B10
    Pitch A = A: UNISON
    Pitch B = B: UNISON
    Delay A = 0 ms.
    Delay B = 0 ms.
    (encoder) = HMODLTR / TMP: OFF
    Depth / Key = DP: – 30c
    Speed / Scale = SENS:  2  to  5*
    Xnob = ENVELPE
    Ynob = FBK:  0
    (EXP PED Heel) =  DP: -30c
    (EXP PED Toe) = DP:  30c
    *Set the envelope sensitivity in Speed / Scale to your playing style, or to the desired depth of chorusing.  A setting of zero or 10 effectively knocks out the 'envelope' part of this preset.
    The PitchFactor envelope appears to act on discrete input levels.  That is, it doesn't seem to be an envelope follower in the strictest sense.  One threshold level triggers the effect, and when the input drops below another threshold, the effect drops out suddenly, too.  Still, there's quite a variety of responses to be found using the SENS: setting, in conjunction with your playing technique.
    Expression Pedal:
    Heel position has 30 cent pitch variations going both higher and lower (for a deeper 'chorusing' effect).  More subtle variations can be found in the midrange of the pedal.  The Toe position has pitch shifts both going upward, and the actual pitch variations become reinforced, and more noticeable.
