Home Forums Products Stompboxes PitchFactor Preset Programming: “Other” Effects Reply To: PitchFactor Preset Programming: “Other” Effects
#135317
    GrainDelayPedal
    Mix = WET: 25 – 50
    Pitch Mix = A10+B10
    Pitch A = A: 1.000
    Pitch B = B: 1.000
    Delay A = 50 ms.
    Delay B = 50 ms.
    (encoder) = 910/949 / TMP: OFF
    Depth / Key = H949-1
    Speed / Scale = MICRO
    Xnob = FBKA: 25
    Ynob = FBKB:  25
    (EXP PED Heel)* =  A: 0 ms.  B: 0 ms.
    (EXP PED Toe)* = A: 2000 ms.  B: 2000 ms.
    At default settings, this is just a slapback echo with some decaying repeats.  The first 949 algorithm adds some graininess to the flutter echoes.  Legato playing results in almost a small room reverb response.  Adjust the Mix setting to the desired depth of effect.
    *Expression Pedal:
    It's not necessary to get exact, identical settings for Delay A and Delay B; at either the Heel or Toe position.  In fact, slight differences between the two delays enhances the granular reverberation effect.  As the expression pedal moves from Heel to Toe, the control over the delay times slurs the repeats, and introduces short crossfade effects.  Shorter delays are 'captured' in longer delays, and echoes appear to be arriving from many different directions.
