Home › Forums › Products › Stompboxes › PitchFactor Preset Programming: “Other” Effects › Reply To: PitchFactor Preset Programming: “Other” Effects
#135318
    FilterSplatter
    Mix = WET: 50
    Pitch Mix = A10+B10
    Pitch A = ArpA: OFF
    Pitch B = ArpB: OFF
    Delay A = A:06
    Delay B = B:06
    (encoder) = PEGGIATR / TMP: OFF
    Depth / Key = ATK:  10
    Speed / Scale = LN:  450 ms.
    Xnob = FXA:  RnFL
    Ynob = FXB:  RnFL
    (EXP PED Heel) =  LN: 450 ms.
    (EXP PED Toe) = LN: 75 ms.
    Slow filter changes resembling a stepped wah effect.  The sharp attack clips the filter to the first 1/10 of the 'step', with accents provided by the almost-steady groove pattern selections.
    Expression Pedal:
    The large increase in rate blurs the random filter patterns together, and stops just short of a gargling mess.  Again, this is a preset that's not tied to tempo, and meant to be used in & around the current rhythmic pulse.  Consider it an Alien Leslie effect, with the EXP PED ramping the effect up and down in speed.
