Home Forums Products Stompboxes PitchFactor Preset Programming: “Other” Effects Reply To: PitchFactor Preset Programming: “Other” Effects
#135319
    MultiOctavia
    Mix = WET: 80
    Pitch Mix = A10+B10
    Pitch A = FLTA: 0
    Pitch B = FLTB: 50
    Delay A = RES-A  10
    Delay B = RES-B  10
    (encoder) = OCTAVER / UNUSED
    Depth / Key = DPTH:  25
    Speed / Scale = SENS:  100
    Xnob = FUZZ:  7
    Ynob = oct ……….|| fz
    (EXP PED Heel) = oct ……….|| fz
    (EXP PED Toe) = oct …..||….. fz
    The Octaver algorithm's fuzz parameter has some of the squawky characteristics of the legendary Octavia pedal.  As with the original, you'll hear more of the breakups & octave-up effects with double stops and with notes above the 7th fret.  I didn't max this one out at Fuzz: 11 (nice touch, Eventide!).  Rule of thumb: Cleaner input; more fuzz.  Distorted input; less additional fuzz required.
    Expression Pedal:
    Here's where the 'multi' part comes in.  The default preset is nearly all fuzz, with just a touch of the two suboctaves.  The Toe position on the expression pedal mixes in resonant filter suboctaves in equal amounts.  Use it to add a riffing bassline, or to break up the distortion-fest even more.
