Home Forums Products Stompboxes PitchFactor Preset Programming: “Other” Effects Reply To: PitchFactor Preset Programming: “Other” Effects
#135323
    ScratchLoopDelay
    Mix = WET: 50
    Pitch Mix = A10+B10
    Pitch A = A:  UNISON
    Pitch B = B:  UNISON
    Delay A = A:  1/8
    Delay B = B:  1/16
    (encoder) = DIATONIC / TMP: ON
    Depth / Key = (any) N/A
    Speed / Scale = (any) N/A
    Xnob = FB-A:  75
    Ynob = FB-B:  75
    (EXP PED Heel) = B:  1/16
    (EXP PED Toe) = B:  1/2
    Quote:
    Xnob (Ynob)
    Controls level of Voice A (Voice B) feedback.  The feedback delay length is Delay A or Delay B, whichever is longer.
    The excerpt above (from the Diatonic section of the UM) explains the idea behind this preset.  In the default settings, this is just a rapid ping-pong delay with a somewhat long decay time.  But when you start to vary the delay times …
    Expression Pedal:
    By controlling the delay time in Delay B, the expression pedal shifts the feedback delay length between the 1/8 note static setting in Delay A, or the current expression pedal setting (if it's longer than an 1/8th note) in Delay B.  Active use of the EXP PED yields scratching & stuttering delay effects.  The feedback length remains sync'ed to tempo, but the changing divisions result in a very unique delay effect.
