Reply To: Y cable to split EV5 expression pedal for MF and PF
Home Forums Products Stompboxes Y cable to split EV5 expression pedal for MF and PF Reply To: Y cable to split EV5 expression pedal for MF and PF
#135334
I can't give any hints about avoiding ground loops – each setup is a thing in itself. I just wished to alert you to a potential problem if you couple the two stomps together via a shared pedal.
Try it and see – it will probably be OK.
