Home › Forums › Products › Stompboxes › H9 Midi Program Change Map › Reply To: H9 Midi Program Change Map
#135845
gkellum
    If you have another Eventide power supply handy, it would be good if you could try using that with your H9 to see if you still get the same behavior.  If you don't, would you mind sending a quick email to support@eventide.com just saying that you've been having problems getting your H9 to save your program change mappings using the standard Eventide power supply?
