Home Forums Products Stompboxes Hotknob patch…clarification about Reply To: Hotknob patch…clarification about
#136082
AAgnello
    "I can assign MORE then one single parameter to any X, Y and Z button once in Hotknow Patch function…right? This mean, after saving new settings, I push button X (where I assigned 3 different parameters with theis min-max value) and "MOVING" the Hotknob I "MOVE" all 3 different parameters assigned values?"
    No. The HotKnob button allows you to change multiple parameters. The X, Y and Z buttons always change only one parameter at a time. For example, you can program the Hotknob to change delay and mix at the same time and save that HotKnob assignment with your preset. Then, when you load that preset, if you press the HotKnob button, turning the big Knob (the encoder) will change delay and mix according to the range that you programmed.
