Home Forums Products Stompboxes New EQ compressor doesn’t work? Reply To: New EQ compressor doesn’t work?
#136568
wedelich
    Out of curiosity, how are you plugging your mic into the H9?  If you don't have a mic pre before the H9, it's possible that you're signal is too small and is below the Gate that included in the EQ Compressor algorithm.  Have you tried turning the Gate Off in the EQ Compressor?  It works the same way as tempo on/off in the other algorithms.
