Home › Forums › Products › Stompboxes › New EQ compressor doesn’t work? › Reply To: New EQ compressor doesn’t work?
May 6, 2014 at 3:19 am
#136590
Hi, yes, we talked about it today. I wanted to ask you whether you have your mic plugged into input 1 or input 2 of the H9. It should be plugged into 1… If an input is plugged into input 2 and nothing is plugged into input 1, things might not work correctly.
Also, you have a rather unusual set-up. We were wondering whether for the purpose of just figuring out his problem whether you could temporarily try plugging a guitar or something similar into the H9 and see if the behavior is the same.
