Home › Forums › Products › Stompboxes › PitchFactor Preset Programming: “Other” Effects › Reply To: PitchFactor Preset Programming: “Other” Effects
#136601
    I'm running into the same issues that you are, Stax_911 (and I'm using the same roadmap to import).  I found a reply on the forum from gkellum [Eventide] that mentioned the *.H9z format as a form of compressed zip file.  It went on to suggest renaming *.H9z to *.zip, then extracting the preset or preset list.  I'm sure that it referred to an ealier H9 Control version.
    Since I compressed the file *twice* (zipping all of the H9z files together), maybe that corrupted something.  Just moments ago, I downloaded my own upload, extracted it to a separate folder, and tried importing.  The Preset List won't import – period, and some – but not all – presets import as singles.  Let me try a few more things (including .syx file archiving from FactorLib), and see what I can come up with.
    I'm tempted to delete the download until I sort things out, but perhaps Eventide can use it to analyze the export / import process from a user standpoint.  Next time, though, the new upload won't "double-compress" the files.  BTW: I exported everything from either the Preset or Preset Listing screen, not the Settings tab.  I know of no other way to import (but drag-and-drop would certainly be welcome).
    Thanks for your feedback, Stax_911.  I'm going to get this download fixed.  The irony is – I was waiting for PitchFactor support in H9 Control to compile all of these presets-on-paper.  And when I tested the files before upload, I must have clicked on several of the presets that imported smoothly.  Back to the virtual drawing board …
