Home Forums Products Stompboxes Musicom Lab EFX 3- Help…. Reply To: Musicom Lab EFX 3- Help….
#136671
    I'm not sure that I understand, but I think you are trying to control 3 stompboxes with a pedal connected to the first one.  This will not work (although we (Eventide) should consider allowing a connected pedal to be a MIDI control source).
    For now, you probably have two options:
    1) Use a MIDI pedal.  This sounds like the solution, but probably will not work, as you presumably have each box set to a different MIDI channel.
    2) Make (or have made) a 3 way 'Y'-lead so that you can directly connect  a pedal to the 3 pedals. This will work, but there is a risk of ground loops if you are not careful.
