Home › Forums › Products › Stompboxes › H9 Y cable for exp pedals › Reply To: H9 Y cable for exp pedals
July 8, 2014 at 5:03 pm
#136983
"The TS connecting to the tip of the TRS goes to the pedal. If you use TRS to TRS, the pedal and switch will interact."
could someone clarify this a bit? when you say "pedal" are you again reiterating the H9, or are you talking about the expression and bpm pedals? also- is that last sentence a typo? did you mean they WON'T interact?
