Home › Forums › Products › Stompboxes › H9 midi preset switching engage issue › Reply To: H9 midi preset switching engage issue
For the four buttons on the DMC-4 what I'd like to happen is:
Top left is either hold or tap, right now it's tap, I have yet to get this to work
top right is engage/disengage when held, the tap on this switch changes modes on the DMC-4. This currently works as expected
The bottom two switches are prest scrolling, preset up and down. These work currently, however when I scroll, if the pedal is not engaged, the scroll (tap of bottom left or right) not only scrolls the preset but also engages the pedal. This is the behavior which I'd like to change. When I scroll prests using these buttons the preset engages currently, I would like to be able to scroll to a preset and then manually engage the pedal.
