Home › Forums › Products › Stompboxes › Lag when controlling expression knob via midi › Reply To: Lag when controlling expression knob via midi
#137187
MarcoR
    I also use a Liquid Foot +
    12 + and have the same issue with an expression pedal controlling the the
    factor pedals (not H9) via midi.
    For example, using the
    expression pedal to control PitchFlex responds slowly; it goes from 0 to 100
    moving the pedal slowly but if you move it quickly, it just jumps to 0 or 100.
    Same behavior using the expression
    pedal through a midi solution box (no LF involved)
    So I do not believe it is
    the Liquid Foot. Also, the Liquid Foot controls my Lexicon PCM 80 without the
    lag.
    Using an expression pedal
    connected to the pedal jack on the factor pedals works as expected. Controlling
    the switches via midi CC works perfectly but trying to control any of the knobs
    or the pedal has the lag.
