Home Forums Products Stompboxes Lag when controlling expression knob via midi Reply To: Lag when controlling expression knob via midi
#137194
    I'll try MIDI Solutions…..
    The pedal input will work better because it only measures the input when it is ready and does not have the "rubbery" message queueing issues that you are seeing with MIDI.
    I would expect Space to be the same as the others – this part of the code is common.
