Home Forums Products Stompboxes Latency in factor pedals set with the DSP-bypass option? Reply To: Latency in factor pedals set with the DSP-bypass option?
#137333
Goldglobe> I saw in some other tread that you got the timefactor to work well with the mesa parallell effects loop. How did you do that? Maybe i can try the same method.
As it is now its either DSP – phase problems (amp and effects sounds crap) or Relay (true bypass) – big volume drop when effects are engaged.
Also i read a bit about the series loop mod on the mesa, the design on the amp doesnt really make this work, since you will have a bit of dry signal in the mix either way. The mesa mix (on effets loop) are not 0-100 % but 10-90 % for some reason…
