Home › Forums › Products › Stompboxes › Latency in factor pedals set with the DSP-bypass option? › Reply To: Latency in factor pedals set with the DSP-bypass option?
September 11, 2014 at 3:04 pm
#137334
Sorry, must be a mistake, I've never actually owned a Mesa, and I've never solved the parallel loop problem without having it modified to series (I had this done to a small Laney amp) . My local tech guy showed me on the schematic what he did…it was simply a matter of removing one wire and moving another…something like that. It might be slightly different on the Mesa, but I don't think the mix knob will even come into it…with series you won't need it. Best thing I think is to take the schematic to someone local who knows about amps.
