Reply To: H9 looper printable user guide
Home Forums Products Stompboxes H9 looper printable user guide Reply To: H9 looper printable user guide
#137817
Lonny Jarrett
Hello, I'm putting together a pedalboard and had purchased a TC ditto to use as a looper. However, with the sweet deal on the H9 max I've just bought a 2nd H9 for the board. Now, it occurs to me that I can just use that as the looper when I want to loop.
Here is my question: If I have both H9s linked serially in my amps effect loop, will the the second still work as a looper? I'm used to having my looper before the amp.
My inclination would be to have a mono signal feed the H9#1 then to take the stereo outs into the stereo ins on H9#2 with a single output going to the looper and then into the amps front end.
OR
Should I just take the amps effect send into input of H9#1->H9#2-> amp return?
Thank you!
