Home › Forums › Products › Stompboxes › Bluetooth issue with 2 H9s simultaneously › Reply To: Bluetooth issue with 2 H9s simultaneously
January 8, 2015 at 1:15 pm
#137946
No luck. I reset the iPad twice (once was network only, and then everything). I turned Bluetooth off/on at the iPad and on the H9s. I can pair H9-1, but not H9-2, or I can pair H9-2, but not H9-1. Either one will pair by itself, but not both at the same time.
I watched the H9 displays closely. The iPad will briefly say connected, but the Bluetooth LED indicator on the H9 never illuminates and after 2-3 seconds, the iPad goes back to disconnected.
Should I try a factory reset on the pedals? I seems to be some sort of contention between the two of them.
