Home › Forums › Products › Stompboxes › H9 looper issues discussion › Reply To: H9 looper issues discussion
#138226
wedelich
    Hi teabandito,
    Are you referring to the Switch on the H9, or to an actual physical and separate Aux switch?  If it is a separate Aux switch, will you kindly detail exactly how you have programmed in System Mode, so we can try to duplicate your issue?
