Home Forums Products Stompboxes H9 looper issues discussion Reply To: H9 looper issues discussion
#138261
teabandito
    Ok, i shot a video on my last rehearsal, so you can see how it actually looks and sounds.
    Looper:
    Previous preset (but looks like id doesn't depend from what preset you go to lloper)
    Here is the video. The left button is play, the middle is rec, the right is stop. So when load the looper i stop it, because i don't need to record anything this time. Then i push rec and sometimes it hangs immediately with that drone sound, sometimes it lets me record one loop and even plays it first time, sometimes it records till the middle and then playbacks the fall of the pattern which i tried to record. On the last rehearsal it it was freezing like 99% of times. Switching to other preset did not help, turning it off and then again on also did no affect to this issue
    http://youtu.be/mJbl9A1nOA8:550:0
