Reply To: H9 looper issues discussion
Home Forums Products Stompboxes H9 looper issues discussion Reply To: H9 looper issues discussion
#138297
wedelich
Thanks, I just wasn't sure we working on the same page.
As a side note, you shouldn't need to press Stop after you load a Looper Preset because Looper always loads Empty.  That might be the cause of some of the intermittent behavior.
When you use the Looper without any Looper Aux Switch designations, is the drone bug still there?  Or does it work like you think it should?
Also, to re-iterate, the Aux Switch will list presets if the Looper is in Preset mode (press and hold the Right Footswitch to put the H9 Looper in Preset Mode).
Thanks for hanging in there with me….
