Home Forums Products Stompboxes H9 looper issues discussion Reply To: H9 looper issues discussion
#138359
wedelich
    wedelich:
    spencerjacob:
    H9 in general. This happens when I am in normal mode just switching through presets.
    Sorry, I looked for a thread and didn't find an appropriate one. I didn't want to start a new one either.
    This is certainly not normal.  It should switch presets very quickly when using the footswitches. Can you describe in detail, exactly what you're doing on a step by step basis?  As in:
    1. Starting from preset # XX
    2. Use right footswitch to cue up preset # XY
    3. Press left footswtich to load preset….
    4. Etc, Etc.
    Also, what is your exact setup, are you running in an effects loop, in front of an amp, direct?  Are you using killdry?  Etc.
