Home › Forums › Products › Stompboxes › Adding a Swell/Volume pedal function › Reply To: Adding a Swell/Volume pedal function
#138383
ROBLEISHMAN
    Why not? This is how the current parameter system works right? chances are if you need a swell, your not going to have a wah effect at the same time right, so you could make 2 versions of the preset, 1 with swell hotknob values another with filter values…
