Home Forums Products Stompboxes Question about H9 control via Bluetooth Reply To: Question about H9 control via Bluetooth
#138505
BCy2k
    Thanks for your reply.
    I'm not getting the MIDI out from the BlueBoard to do anything on the H9 so far. As I previously mentioned, I think I've made all the necessary settings between the two (BlueBoard & H9) to get that to happen, but still no luck there. I'm not ruling out operator error, but I've run out of obvious things to check. I'm pretty much stumped at this point.
    Looking forward to hearing back from you RE trying out your associate's BlueBoard with the H9. It all looks so good on paper ;o)
    I agree RE the oddities of the BlueBoard not having hardware MIDI I/O.
    It would seriously make my day to get all this to work they way I'm trying to. Might there be a way to get H9 to pass the bluetooth MIDI it receives to it's MIDI out/thru port to other devices at some point? As you've noted, this would be a huge help for at least some users. Thanks.
