Home › Forums › Products › Stompboxes › H9 – problem connecting & syncing to DAW › Reply To: H9 – problem connecting & syncing to DAW
#138638
gkellum
    Vonoom:
    I'm still having the crash issue with H9 Control, as it is still trying to connect with my soundcard, and when I click on 'Connect midi device to eventide device' to remove the connection, Control crashes.
    In H9 Control click on the Settings button in the bottom right hand corner of the screen and go into "Reset Settings" and use the "Reset All Settings" button to blow away you're settings.  You'll have to go through the registration process for your H9 again after doing so, but this will take care of that crashing problem.
