Reply To: H9: Jumpy MIDI response
Home Forums Products Stompboxes H9: Jumpy MIDI response Reply To: H9: Jumpy MIDI response
#138691
My guess is that if you send it the 128 values in quick succession, it will process them all as quickly as it can, and only then allow the resulting parameter changes to ripple through. This means that the last one received is the one you hear.
Obviously, this will not give you the smooth instant ramp you would like, but is probably the way it works. If it activated the parameter changes after every message, it would become seriously slow.
