Home Forums Products Stompboxes tap tempo sync between space and modfactor Reply To: tap tempo sync between space and modfactor
#138725
blacky1956
    Thanks a lot for your quick reply! It helped
    but now there is another problem:
    It would help if you describe your setup a
    little more:
    – Is there any other devices conected before,
    after, or in between those 2 ?
    • In what order are they?
    Yes, there is an other device before. At
    first I use a BEHRINGER FCB 1010 Midi Foot Controller, after it the
    „space“ and at last the „modfactor“ is the order of the midi
    connection. I use the midi foot controller for changing presets in
    „space“ and „modfactor“ and MIDI continuous dates for
    Knob0-Mix on „space“ and Knob0-Intensity on „modfactor“.
    In any case both could set tempo from a midi
    clock, but according to p.:32 of the "space" manual and p.:
    27 of the "modfactor" manual only the "space"
    could be used as a clock source.  You will then want to put the
    "space" before the "modfactor", unless you have
    something else that could generate the midi clock.
    – For the "space" you will then set
    [MIDICLK OUT]  -> ON. See page 37 of the space manual. (And
    MIDI Output to XMT)
    – For the "modfactor" you will set
    [MIDICLK] -> ON.  See page 35 of the modfactor manual.
    I have done it and tempo
    change between space and modfactor works! Thanks!
    But now the preset change only
    works from the midi foot controller to the space and never works
    with the modfactor, because MIDI Output on „space“ is set to XMT.
    By sending preset changes from
    footcontroller to „space“, the tempo of „space“ preset
    changes the tempo in the „modfactor“, that´s all right but the
    preset never changes with it but stays the same. Why is that?
    So what can I do to use the
    midi footcontroller for sending preset changes AND MIDI continuous
    dates to both stompboxes and after it setting sync tap tempo by
    „space“ and „modfactor“ by using tap tempo by „Space“?
    My MIDI settings:
    BEHRINGER FCB1010 Midi Foot
    Controller:
    Midi Channel: 1
    Eventide Space:
    RCV Channel: 1
    XMT Channel: 2
    CTL XMT: off
    PGM XMT: off
    OUTPUT: XMT
    MIDICLK IN: off
    MIDICLK OUT: on
    CLK Filter: off
    Eventide: Modfactor:
    RCV Channel: 1
    XMT Channel: 2
    CTL XMT: off
    PGM XMT: off
    OUTPUT: XMT
    CLK IN: on
    CLK OUT: off
    CLK Filter: off
    With friendly greetings
    Blacky
