Home Forums Products Stompboxes H9: Jumpy MIDI response Reply To: H9: Jumpy MIDI response
#138778
    I'd like to look at this issue, since it seems to be causing distress, but I need a suitable pedal for testing – I'm not having luck getting hold of those that have been mentioned as causing the problem
    1) Moog MP-201 is discontinued.
    2) Liquid Foot people are unresponsive.
    Can anyone suggest a specific currently available MIDI pedal that they know causes problems with our pedals.
    Please don't say "they all do," or "try a DAW," because I can be fairly certain that if I try any generic solution, it will work faultlessly and I shall be none the wiser.
    Equally, using a generic pedal with a MIDI converter will have results partly depending on the characteristics of the pedal.
    These problems have only started being reported in the last 6 months, so I suspect it may mainly apply to more modern products.
