Home Forums Products Stompboxes H9: Jumpy MIDI response Reply To: H9: Jumpy MIDI response
#138906
LA Keys
    DeanStel121:
    I use a Ground Control Pro and 2 x Ernie Ball VPJR  …  When mapped through the GCP to send CC02 and the H9 "Set expression value" is set to 02, the H9 will not respond at all to the VPJR
    This should somehow work, but only if you slowly move  the pedal. The problem appear to be that the H9 is not able to respond fast enough to relatively fast motion on the pedal. If you go slow it should respond.
    Mr Nickrose: Did you had a chance to test with a MIDI generated CC sawtooth like you mention on a previous post. I believe that some of us really hope that this issue could be resolved…
    LA
