Home › Forums › Products › Stompboxes › H9 and MIDI Solutions Quadra Thru › Reply To: H9 and MIDI Solutions Quadra Thru
May 21, 2015 at 2:16 pm
#139168
Hi guys,
Thanks for your replies.
JCR, I tried connecting the Quadra Thru in the manner you suggested, but still to no avail. Perhaps the Quadra Thru is wired differently than the Merger?
In any case, I will likely be returning the Quadra Thru and replacing it with a Molten Voltage MIDI Splitty, which should hopefully do the trick.
Thanks again for your help.
Best,
Andrew
