Home Forums Products Stompboxes Timefactor Looper question Reply To: Timefactor Looper question
#139364
    A portable mini-audio recorder works (I’ve used a Microtrack 24/96).  It easily fits in a guitar case or gig bag.  Trim the audio beforehand in an audio editor, and save clips as individual .wav files.
    An advantage to using a computer / sampler with MIDI capabilities is that you can somewhat automate the process.  Send a Start / Stop message to both the DAW sequencer and H9 / TimeFactor (or generate them within the application).  Sample playback and looper recording begin & end together.  Mute, and switch tracks to repeat the process with other samples.
    There has to be similar options for tablets or iPads.  A hardware drum machine can be used as a “System Real Time” generator.
