Home › Forums › Products › Stompboxes › Pre/Post Bypass Path › Reply To: Pre/Post Bypass Path
July 15, 2015 at 5:25 pm
#139721
Hi Nick, just for clarification. Let’s say that the H9 is activated in “pre”, wired up through input/ output 1. Input / output 2 are of course also wired up although not in use … but the signal still needs to go through them so as to not break the chain. Are input / output 2 relay bypassed or does the signal run through the converters again?
So basically, does pre/post routing mean that the dry signal must run through the digital converters twice? Thanks.
