Home › Forums › Products › Stompboxes › “Click” in on/off › Reply To: “Click” in on/off
#139863
    Assuming by connect and disconnect you are referring to power, this is probably the bypass relay. The unit goes to relay bypass on power down, however the actual bypass mode is set.
