Home › Forums › Products › Stompboxes › Updating H9 for CrushStation and Pre/Post Routing Options › Reply To: Updating H9 for CrushStation and Pre/Post Routing Options
July 25, 2015 at 4:13 pm
#139897
wedelich wrote:
Emanuele Sereni wrote:
I am a happy owner of two H9, licensed Max.
I immediately made a update to test the new algorithm Crushstation.
Very nice I have to say, but I’m afraid that at the moment there are bugs.
When I lower the volume knob (about half) and when pinch the strings gently H9 fails to capture ALL the notes you play, but only some.
In the same way with these settings when play a long note the decay of the sound is not gradual, but passes from 100% to 0% immediately
Load a small video
Others of you have experienced this problem?
https://www.youtube.com/watch?v=X0VrNnnn4l0
Is the Sag parameter turned up? This can act like a Gate. You can just turn it down if so. Also, if the Gate is ON and your guitar signal is somewhat quiet this could happen. Either turn the Gate OFF or increase the Input Gain into the H9.
Do either of those suggestions help?
hello, I checked on ipad and saw that all presets (except one) the key “gate” is always on.
Turning it off is no problem
Thank You
