Home › Forums › Products › Stompboxes › Crushstation volume issues › Reply To: Crushstation volume issues
#139902
Adamixoye
    brock wrote:
    I had very similar symptoms with CrushStation.  It turned out to be (partial) phase cancellation in my signal chain.  I’m running mono-to-stereo [ /dual mono] on my pedalboard, and the ‘split point’ was my AdrenaLinn III.  Evidently, the right output isn’t perfectly in-phase with left/mono out.
    When I took it out of the signal path, and let another device (PitchFactor) mix internally, the 12dB boost for CrushStation presets was no longer required.  That also solved a longstanding problem that I had with the PitchFactor’s HarPeggiator fuzz effects.  I’m not saying that this will mirror your own issue, but it may be a diagnostic worth looking into.
    That’s interesting but doesn’t apply to my setup as I am running things completely mono.
