Home › Forums › Products › Stompboxes › Going between reverb and delay w/tap tempo › Reply To: Going between reverb and delay w/tap tempo
July 27, 2015 at 3:49 pm
#139917
You can just save two presets if you like and the right button on the H9 (with the label "Tap" above it) cycles you through the presets. Hit active on the first preset (left button) then hit the right button to advance to the next preset. The new preset flashes but isn't active until you hit the active switch again. Now you're using the second preset. None of this requires the use of an aux switch. Does that answer your question?
