Home Forums Products Stompboxes Crushstation volume issues Reply To: Crushstation volume issues
#139962
wedelich
    Adamixoye wrote:
    I tried guitar –> H9 –> amp with no other pedals.  I used two different guitars.  On both the bypassed signal was significantly louder than the effected signal for a wide range of settings and different presets.  I tried it with the mix at 50/50 and the clean signal was much louder than the dirty signal.
    My bass was a little harder to tell—levels seemed a little more comparable, and the EQ made a huge difference.  I only tried one bass.
    So what CrushStation presets are you using, and what are the settings?  This might matter b/c your guitars could be sitting on the compression curves and gain curves differently depending on their input levels.   Also have you tried adjusting the input gain of the H9?
