Home › Forums › Products › Stompboxes › Save my banks with differents bpm › Reply To: Save my banks with differents bpm
what configuration i use to save my banks with different bpm ? Currently my settings make me work with the last bpm save on all banks, but i need work with 100 bpm on my bank 1:1 … 75 bpm on my bak 1:2 … 130 bpm on bank 2:1 … it's possible ?
If I understand you correctly, you have global tempo enabled. So, the same tempo is being applied to all of your presets. You can turn global tempo off and use the tempo saved with each preset. But the tempo is saved with the preset and not the bank. So, if you want two presets in the same bank to have the same tempo you will need to save each preset with the same tempo. This should be pretty quick and easy to do though with H9 Control.
