Home › Forums › Products › Stompboxes › H9’s Looper bug › Reply To: H9’s Looper bug
August 18, 2015 at 4:54 am
#140186
Hey, thank you so much for your help.
I will install a MIDI monitor to see if there’s something weird happening when sending that CC. Any suggestion?
If you guys aren’t able to reproduce that then is most likely an issue with my LF+ Mini and my H9 setup.
Correct me if I’m wrong with this workaround: send a CC for knob8 with a low value (0?) to “hit” the -2x Rec-Speed and then send the same CC with a high value (~110) to “hit” 1x.
Thanks for everything!
